Hello all,
Planning the layout for the water supply lines for my master bathroom remodel. I will be switching from copper to PEX.
I'm pretty much using the same configuration that was already there except the builder used a bunch of tees right at the main pipes coming in and branching from there, where i have tees at different points along the way. The cold main gets reduced to 1/2. Everything is 1/2 from there.
For context, we had a double sink vanity before, i will be having a single vanity on opposite sides of the room now. I don't recall having a pressure issue when running both faucets at the same time, but honestly my wife always kept a bunch of makeup and crap on "her side" and just used mine. I am concerned about the 2 showers running at the same time though. Before if the shower was running and the sink was running you could feel the pressure drop in the shower, especially on the hot side. Both showers will have their own control valves. i think the most likely scenario will be 1 shower and the tub running at the same time than both showers running at the same time. But id like to avoid the pressure issue in any scenario where multple fixture are open at the same time.
My questions are, does anyone see any potential issues with this design? And would i be better off leaving the cold main at 3/4?
I have not bought the actual fixtures, so I don't know if they come with 3/4 inlets or not? And probably less likely to have just the cold inlet in 3/4?
Any feedback is appreciated!!
