Jonny John
I am not sure of the type of spiqot I have. I know it has a gate. Not sure of the brand. I will take a look and maybe take a picture for you guys if that would help determine?
The piping going to the spiquot is 1/2 copper piping. Is this okay?The pressure reading indicates that you have enough pressure, and there is a restriction in flow.
What hose bibb is it? Some hose bibbs don't have a very big opening and they restrict flow. American Valve makes a ball valve hose bibb that is full flow, available at Lowe's. The ball valve hose bibbs at Home Depot are from Mueller and they have a small ball and restrict like 2/3 of the flow.
I've never heard of a hose bibb with a gate valve, usually they have a globe valve or ball valve. It's probably a globe valve (piston with rubber washer that presses on the hole when screwed in to stop the water)I am not sure of the type of spiqot I have. I know it has a gate. Not sure of the brand. I will take a look and maybe take a picture for you guys if that would help determine?
should be fine; that is normal.The piping going to the spiquot is 1/2 copper piping. Is this okay?
So the flow has always seemed to be the same?Never really paid attention to the water pressure to the spiqot until now. Been living in the home for 4yrs.
No first take the spigots off and test the flow to see if the issue is with the spigots or not.Do you feel I should replace the spiqot? I can pick one up at HD or Lowe's before heading home to take a look at it
???I never have both spiqot's running at the same time. I mostly only use the spiqot in the front of my house. I
No. Don't take the pressure gauge off for the test. Get a helper to open the *other* spigot while you watch the gauge. Alternatively, open the other spigot, and go around look at the pressure gauge before shutting off the open spigot. The purpose is to see if there is a restriction before the point where the supplies for the two spigots separate.I posted a picture earlie when I put the pressure gauge on the spiqot.
I will take the spiqot off and test the water flow.
This tells you that the problem is not either spigot, and it is not near either spigot. It says that the blockage is before the supply pipe splits to the different spigots.So I put the pressure gauge on the spigot in front of my house. Turned on the water and getting 80 PSI. When I turn on the spigot in the back of the house at the same time, the front house spigot goes down to 0. Once I turned the back spigot off, the front spigot goes back up to 80.
That test I proposed in post 36 was to test for that. If you saw a big pressure drop at the outside pressure gauge when you turn on the bath tub or kitchen sink etc, then the problem would be before the valve.Could it be the piping before the valve?
