Brizine
First, thanks in advance, I am here to be educated. I have a unique situation that I need help on. I'll start with the well water test results. The lab came back with these numbers.
Total Hardness 284mg/L which equals 16.6 grains by my calculations
Alkalinity 256mg/L
ph 7.53
negative for bacteria
I have a 1500ft house with two occupants, so 2 x 75= 150 gallons per day. Now the unique part, I also run a business off the same well that has a 2400ft building that averages 600 gallons a day, five days a week, 5.5 months a year. We fill a 1500 gallon holding tank about twice a week. The other 6.5 months a year, the shop may use 50 gallons a day.
I am wanting to add a fleck 9100sxt water softener twin tank softener, so as to not run out of soft water. Please advise if this softener choice is the correct for my application and what size system to purchase. I will also be adding a sediment filter before the softener. Also is the alkalinity acceptable? Any suggestion or recommendations are appreciated.
Thanks,
Brian
Alkalinity 256mg/L
ph 7.53
Thanks,
Brian
