Water Softner/PH education
Westchester, NY
Hello everyone
I looked into Water Softeners several years back, but put it on the back burner at the time. I need to revisit. I had my water tested late last year. The test results are below. I have a sediment filter in place because I'm getting some fines coming through. We are a family of 5, with 2.5 bathrooms. We are on well water
I have been reading all the posts today and trying to learn about water softeners. I need some clarification on several items. Hope some of the experts here will be kind enough to help.
I see a lot of comments about valves being the critical component - Clack, Flack, etc, being the better ones. Which are the recommended systems I can buy that have these better quality components?
Can anyone point me to any layout so I can get a good idea of the installation requirements? Trying to figure out what plumbing effort is required and what space I need to have set aside for the components.
Backwash/brine and regeneration - Is this a function within the system, or do I need to add it in separately?
PH normalization - is this a separate solution also? ( Corrosion is my bigger issue, I think)
Drinking water - we currently get bottled water into the house. Can this be eliminated with a water softener solution?
Drain - Can I tie this into my septic? I do have some cast iron pipes (will the drainage water cause corrosion?) Will the system have the ability to pump the wastewater up 7-8 feet so it can gravity feed into my septic lines in my basement?
Anyone care to take a stab at helping me figure out what spec system I would need?
appreciate any help you guys can throw my way.
Thanks
Water test shows no problem to my thinking. 5.38 grains is considered hard by some, but most people with that hardness would not feel the need for a softener. If you really want softer water, it is not extravagant. Do you feel you have a problem? pH 6.58 is not that acidic, but could be a little hard on metal pipes. EPA draws the line at 6.5 pH... https://www.epa.gov/sdwa/secondary-drinking-water-standards-guidance-nuisance-chemicals and that is just a secondary standard. Plastic pipes would have no problem with it, and that is not to acidic for drinking water by any means..
You could get a reverse osmosis system. That could eliminate bottled water, but I saw nothing in your water report that indicated it was not good drinking water.
With an RO system, you can get a booster pump to take incoming pressure up to a higher pressure for more throughput. An extra 5 psi would make up for the extra 10 ft on the drain line, and the rest would make the water filter quicker.. I am not shopping for RO systems. So if that is your main concern now, somebody may have a suggestion.
Westchester, NY
Thanks, I do have green corrosion on my fittings, shower heads faucets etc that has caused failure over the years . I've never had a major issue but I can see some pieces that need to be replaced again and I just want to hit it on the head and be done with. Is corrosion caused by hard water or incorrect pH?
Green corrosion is not related to hardness, and would be from pH and copper.
To raise pH, you could inject soda ash, or use (calcite followed by a softener). Injecting soda ash does not increase hardness, but calcite does.
