Water Softner Issues
Discussion in 'Water Softener Forum, Questions and Answers' started by AR_Hills, Jan 11, 2018.
  1. AR_Hills
    AR_Hills New Member
    Oct 7, 2017
    AR
    I recently purchased a softner system via dittohead. It's a two tank 2.5 cf Pentair system with KL.
    The issue is the softner will throw a "No Flow" alarm after about a week or two of light usage. This leads to my H2S2 and hardness issues returning.
    Even with the alarm I'm getting normal output flow, however it seems the water isn't filtered. I can force the alarm off by cutting the main and reopening it after a minute or so. When this happens I can hear the Fleck click over with a rush of water and the Flow Usage Meter returns to normal. The softner is staged after the KL tank.
    My typical flow when it's working is 2.5 gpm with a max of 3.6.
    I'm gone for days at a time and my father said he thinks that the system doesn't like the lack of flow. He suggested a timer on an faucet to run the water for an hour or so a day.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Do you mean that one 13" x 54" tank has KL, and the other 13" x 54" tank has softener resin?
    If so, the one with KL would be called a backwashing filter, and the softener would be the one with the softener resin. So what is indicating an alarm condition?
    What do you mean by that? Are you referring to the numbers in the softener diagnostics? I presume that you are not saying that 3.6 is as much as your pump will put out, because the KL system will need a whole lot more backwash that that. However the backwash of the KL filter would not be reflected in the softener diagnostic numbers.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    I assume it is an XTR2. I would set the Day over ride to every 21 days, this will force an automated regeneration regardless of flow. Call me to go through the programming, it is a little wonky for a forum discussion.
  5. AR_Hills
    AR_Hills New Member
    Oct 7, 2017
    AR
    The softner is the one with the Alarm Code.
    The softner flow meter shows 2.5/7 typically. My well only outputs maybe 8gpm. After the pressure tank and a pre filter it's maybe reaching 5gpm to the KL Filter. So the Softner is seeing half that after the KL.
  6. AR_Hills
    AR_Hills New Member
    Oct 7, 2017
    AR
    I just ran a regen cycle. The issue popped up again after the cycle was completed. The flow meter shows 0.0 and no flow can be felt even with an outside faucet on full blast.
    I have to shut the main off and quickly reopen it for the softener to kick open and start flowing. I'm wondering if my issue comes from the fact my well only outputs 8gpm. I just now noticed the KL Filter also doesn't show any flow.
    Do these filters bypass if there isn't enough flow to trigger the Fleck heads ?
  7. Reach4
    Sep 25, 2013
    KL filter will not have a meter, so it will not show flow. It will be a timed regen. What size is your KL tank -- diameter or circumference?
    No. However a very low flow will not register on the softener. I don't know what the threshold of that should be.
    Normal; the outside faucets don't go thru the filter or the softener. Run the bathtub for your test.
  8. AR_Hills
    AR_Hills New Member
    Oct 7, 2017
    AR
    Same size as the softener - 2.5 cf tank.
    Yeah my house has very odd plumbing. The landscaping and outside water faucets are connected to the house AFTER the softener. In my new piping layout I left a capped bypass pipe for later landscaping use.
    Well something is very wonky with this softener system. My dishwasher is covered in chalky mineral deposits and the water tastes very off. One of my friends gagged on a glass of water this evening. I can stand the unfiltered water but this is a different taste.
    The system worked for about two weeks and since then it's gone south. When I last checked the Hardness yesterday it was just shy of 250 . That is with the system tied in. When I first connected the system the Hardness was basically 0 on the same test strip.
  9. Reach4
    Sep 25, 2013
    Your filter needs something like 11 or 12 gpm to backwash.
    Regarding the white and the taste, could that be salt?
  10. ditttohead
    Jan 9, 2012
    Ontario California
    What size is your pressure tank? This can give you enough water to backwash properly if it is large enough.
  11. AR_Hills
    AR_Hills New Member
    Oct 7, 2017
    AR
    I think I've figured out the issue or issue(s) to be more correct.
    The water coming out of the system, before the house, is insanely soft. My test kit is showing almost no hardness, alkalinity of about 200ppm, and pH of about 8.5.
    The deposits and horrible taste is coming from my WH and my pipes. The water is eatting the 30+ years worth of mineral buildup. So I've slightly opened a bypass I installed to see if I can stablize the water around a 50 Hardness.
    In my limited knowledge. Let me know if I have this hypothesis wrong.
    The "No Flow" alarm was a Red Herring and I think it's a broken or blocked turbine. As it works when I quickly introduce a water pressure head.
  12. ditttohead
    Jan 9, 2012
    Ontario California
    Just run the softener at full softness, it will clear up much quicker than trying to blend.
Similar Threads: Water Softner
Water Softener Forum, Questions and Answers Best inexpensive dyi water softner Apr 25, 2018
Water Softener Forum, Questions and Answers Water softner, acid neutralizer, and nitrate regeneration Apr 23, 2018
Water Softener Forum, Questions and Answers What water softner is this?? Jan 7, 2018
Water Softener Forum, Questions and Answers Water Softner Sizing Recommendations for unique situation Dec 8, 2017
Water Softener Forum, Questions and Answers Water softner bypass valve May 17, 2017
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
