rflagler
After visiting my brother who recently moved to a home with a water softener, my wife expressed interest in the softness of her hair and skin after showering there. I've now begun the process of researching water softeners and could use a little advice. I'm dumping a lot of data here, but I'm bolding my questions to help navigate what may be unnecessary information.
For starters, here is information pertaining to my local city water.
Calcium 29 PPM
Iron <0.01 PPM
Magnesium 9.4 PPM
pH 8.5
TDS 340ppm
Hardness 170ppm/9.94gpg
Chlorine 2.5ppm
Average water usage = 270gal/day
Based on the above data, my usage load is the following.
270gal/day * 10gpg * 1.3 = 3510 grains per day
With that usage load per day, I'm estimating the amount of resin needed to regen at most every 7 days to be the following.
7days * 3510 grains = 24570 grains
For a 3000-3500 grain per pound efficiency I'm sitting between a 1cuft and 1.5cuft resin volume. Would there be any disadvantage to getting 1.5cuft and regen less frequently than 7 days?
I've been reading that there are a few things that can reduce the life of resin. Chlorine, iron, and sediment. We personally don't dislike the taste of our existing water, our iron content is extremely low, and I'm not sure how to know if our water has sediment that would build up. Is there a specific PPM of chlorine that would necessitate a carbon filter before the water softener? I'm not looking to improve water taste, only curious how much chlorine it takes to impact resin life in any meaningful way. In regards to sediment, should I always put some type of filter before the softener, even if it's not a carbon one? Also, is there any need to use a product like res-care if my iron content is so low?
Based on what I've read I was going to get the following.
Flex 5810SXT / 5800SXT Downflow Valve (Depending on supplier. My lines are only 3/4 ID)
1.5cuft of 8-10% crosslink Resin
10"x54" Resin Tank
~240lb Brine Tank
No carbon filter
No Res-care
My biggest question is where to purchase this equipment? I've found the following websites that carry this for similar pricing, but I've read some bad things about getting support from some online suppliers.
ohiopurewater.com
affordablewater.us
aquatell.com
qualitywaterforless.com
isopurewater.com
Lastly, sometimes I feel like I "go all in" on projects and maybe that's not always necessary. Is there any reason buying a basic system from a big box store wouldn't suffice for what I want/need? My brother just picked up a Morton softener for ~$350 and while I'm sure it's not the same quality, would it get the job done for ~1/3rd the cost of what I'm looking into right now?
Calcium 29 PPM
Iron <0.01 PPM
Magnesium 9.4 PPM
pH 8.5
TDS 340ppm
Chlorine 2.5ppm
10"x54" Resin Tank
~240lb Brine Tank
No carbon filter
No Res-care
ohiopurewater.com
affordablewater.us
aquatell.com
isopurewater.com
