So I finally bought a water softener/GAC Filter system. Two tanks - two Fleck 5810SXT's. Installed over the weekend. Programmed appropriately with the retailer but obviously installed myself. Now here's the issue.
I am not getting soft water! I've turned on the cold water to every faucet, regened the unit, and run a total of about 200 gallons through the softener (the meter on the softener is where this number comes from). The result, water with a hardness of 11 gpg which is the same hardness pre-unit. How can this be?
The softener is not in bypass mode (it is in service), it is hooked up correctly with the in's and out's. I just don't get it. What could be causing the water not to soften? The tank has 1.5 cu ft of resin with the gravel bed at the bottom which was provided with the softener. I am just sick to my stomach of the issue here. I've spent a lot of money on a water system and am getting no benefit. The retailer is checking with Fleck but wanted to see what ideas you all had. Picture included to show the set up.
