Venom
Hi All,
In March bought a new home on 22 acres... Very Rural. I am on well water. Installed a new pump and storage tank and used the existing Water Softener. It is a Pegasus Water Systems PM4800 48K Grain unit. It uses a Clack WS1 Valve and a Sta-Rite RT-1054 Tank. Initially you could feel the softened water. A few weeks ago I noticed the water did not feel soft anymore. I checked the hardness and it was the same coming out of the softener as going in.. About 335ppm. I found the softener manual in the pump house which had the original purchase receipt in it. July of 2004 it was installed and never serviced. I figured it was time to change the resin media. I bought 1.5 cu ft of 8% media along with 20lb of gravel. I took the unit apart, drained it washed the inside thoroughly. The feed tube and filter screen looked good after cleaning them. Inserted the feed tube, poured in the grave and added the media. Closed everything back up and did the start up procedure. Once finished I checked the hardness again.. Same thing About 335 both out of the softener and bypassing the softener. I checked the injector and screen both were very clean and working fine. It acts as if the softener is still in bypass mode. The valve seems to be operating properly, it fills the brine tank, pulls in the brine water, rinses and back washes properly. I have not replaced the internals of the valve yet or replaced the bypass valves.. What should be my next move?
Thanks for any help..
