socalal
I recently purchased a Fleck 6700XTR softener system online, and had a plumber install it. He forgot to remove the rubber plug that was in the distribution tube when he installed the valve to the resin tank, so naturally no water came out after the unit was installed and put in service. When he came back to fix the problem, in the process of removing the valve, the distribution tube was raised about 3". He tried to push the tube down as he installed the valve back on the resin tank, but I think the tube was at least 2" higher than before.
The initial water from the softener that came out of the faucets were yellow in color as well. I recently had water heater replaced and installed a whole house filter, and water was never discolored like that, so I don't think it was minerals coming off of my pipes.
I would like to know if his installation mistakes (rubber plug still in place when softener was put into service, raised distribution tube/bottom basket) would cause any problems/damage to the softener system? I was told by the online store that there was no gravel in the resin tank, only resin. What would be the cause for the initial yellow water?
He also installed the whole house filter after the softener. Is that a good thing to do? I thought it should be before to prolong the life of the softener resin.
Any advice would be greatly appreciated!
