Hi all,
I’ve read a lot on these forums and learned a ton. Thanks to all of you for that. I want to bounce a water softener drain line issue off of you all.
I have a GE water softener in my basement. My current drain line runs to my sump pit, and I want to fix that. My manual says that if my water pressure runs between 20-50 psi, I can raise my drain line 8’ from the floor. Over 50 psi, and I can reach up to 14’ I measured my pressure at about 50psi in my first floor utility sink. I have no floor drains in the basement, and I am on a septic.
I can run my drain line up just under 8 feet off of my floor, and run horizontally about 26 feet until I turn to where I can make punch out through the house and drain into my sump pump discharge line which runs underground away from my house. With the water pressure that I have, I don’t think that I will have an issue with back pressure in the drain line. Do others agree?
Second, for installation, could I use braided vinyl pvc and lasso the discharge line to my sump pump drain line until I reach the punch out? I could use zip ties to attach the lines together.
Third, my discharge line is 3/8 ID at the water softener. Some folks have written that expanding the line would be beneficial to reduce back pressure. For example, I could run a few feet of 3/8 ID, then jump to 1/2 and then 3/4. Once the 3/4 exits the house, I would angle it down towards the underground line to ward off freezing.
Do others think this would work OK? Or am I off my rocker today?
