paul8028081
Hello all,
Thanks in advance for any help on this thread. Finally got a professional lab to test my water sample and here are the results for the key areas that are above the state recommended threshold:
My flow rate from my submersible pump is 12 gpm.
My current setup is a Whirlpool 42,000 softener and a 1.5 Cu/ft Birm filter, which is not a good solution. Based on my research the Birm is essentially doing nothing in my pH level and the Whirlpool is lucky to have lasted as long as it has. I currently go through 3-4 bags of salt a month and we don't use that much water.
I've narrowed it down to a Katalox filter for the Iron/manganese and then a 64k grain softener, oversized to take on any additional iron which may make its way through or during a backwash (at night anyways).
Questions:
1.) Do I have a good plan for filter type and softener size?
2.) If so, how big of a cubic foot Katalox system should I look for?
3.) What kind of controller should I look for, looks like most are the 2510 sxt or 5600 sxt Flecks are the norm, but not sure which one is better.
Water Source: Well
Hardness: 129 mg/L or 7.54 grains
Iron: 6.45 mg/L
Manganese: .47/ mg/L
PH 6.68 pH
Turbidity 33 NTU
Radon - 264 pCi/L
Iron: 6.45 mg/L
PH 6.68 pH
Turbidity 33 NTU
Radon - 264 pCi/L
Questions:
