Water smells after new install of 5600 sxt
mf915
New Jersey
I just did the new install today. Went through 1 recycle of regeneration. I notice the water "smells". (and definitely no smell when i bypass the water softener). I read that a few more regenerations might help. Is it common ?? If it doesn't help, should i go with the method of adding a bit of bleach to brine tank and do one regeneration ?
Thanks
5.25% Sodium Hypochlorite
If stronger solutions are used, such as those
commercial laundries, adjust the dosage accordingly.
Dosage for softener resin; 1.2 fluid ounce (35.5 ml)
per cubic foot.
mf915
New Jersey
Thanks. Will try it out.
Also, any pros/cons using those commercial resin cleaner products out there on a regular basis ?
Pro: treat resin for iron.
Con: not cheap.
Some use citric acid (smells good) or Iron Out crystals (smells not good but very effective) to treat iron. Iron-treating salt costs a premium, but has citric acid and something else built in.
Try searching for "smell" in the softener forum using the search box above.
https://terrylove.com/forums/index.php?threads/plastic-smell-with-softener.67090/
https://terrylove.com/forums/index....dd-after-installing-filter-and-softner.64834/
https://terrylove.com/forums/index....t-horrific-smell-when-used-in-softener.55968/
https://terrylove.com/forums/index.php?threads/bitter-odor-only-after-softener.62801/
