Water results suggestions
mikeee321
Massachusetts
Hi all,
I was looking for suggestions on what I could add to my system to help some of these numbers and reduce the greenness I'm still getting all over my copper. I currently have a water softener which was set fairly high for a hardness level based on the hardness (moderately hard), and a ph neutralizer. We only drink water coming from a reverse osmosis system, since we knew the water is bad.
Any suggestions would be appreciated
1. If the sodium level bothers you, you could spend a bunch of money to use potassium chloride instead, or you could get a reverse osmosis filter for your drinking water.
2.
The greenness you see is outside of the pipes, right? Is that outdoors?
