I have a Red-Jacket submersible pump - 150' deep in a 220' well - water level is 108'. It was replaced in 2004.
80 gal Pentair SP-18 pressure tank - replaced in 2010. It isn't waterlogged - I know that from when we had to replace it because of the busted bladder in 2010!
Last couple of weeks pressure has dropped significantly. The pressure switch was working between 40 and 60 psi. Now it reads 30 PSI pretty consistantly. I've checked when pressure is 30 PSI and the pump is on. And I've checked when the pressure is 30PSI and the pump is off, but it's usually on.
I am troubleshooting it and was looking for direction or things to check.
I tried turning the nut in the pressure switch and it didn't make a difference. I bypassed the pressure switch and that didn't raise pressure above 32 PSI.
I tried shutting off power to see what would happen when pressure dropped lower and if it would refill. When I came down to check about an hour later, there was air escaping from the tank and PSI read 0. I turned power back on and about 30 minutes later it's reading 20 PSI and the pump is still on.
Any help or direction is greatly appreciated.
