Several months ago we had faucets dripping, thumping noise in one faucet and a small dripping leak in a pipe in the basement. The plumber measured the water pressure outside at the tap we use for the garden hose. It was at around 85-90psi. He said we needed to replace the water pressure regulator valve. He performed that repair and adjusted the water pressure (I think he set it to 65). A few days ago we started experiencing the same symptoms: water bursts out when I open a faucet, thumping noise in one faucet etc. We left a water pressure measure gauge attached to that outside tap for 24 hours. It showed 100psi. We called the same plumber and he said that this is probably due to the expansion tank failing. Is that even possible? My understanding is that the expansion tank is for hot water only : "The expansion tank’s purpose is to protect your house’s hot water system from excessive pressure". The outside tap never gets any hot water. So my question is: is it possible that the high water pressure is due to the expansion tank failing or is this purely an issue with the water pressure regulating valve?
Thank you,
Thank you,
