ChrisMc
- Messages
- 4
- Reaction score
- 0
- Points
- 1
Hi!
I've had the water pressure regulator replaced in my house once, and the 'guts' swapped out a second time (the plumber said it was easier due to the tight confines, poorly laid out access/plumbing underneath my kitchen sink). In both cases each lasted maybe 9-10 years. At one of those times, the plumber said a 'sign' it was going bad, was that my toilet fill valves would run/start going bad, and my ancient master bath faucet dripped (it's the original builder grade Eljer that I keep nursing along with springs and rubber seats).
Anyway, getting to the point. After the last replacement I purchased one of those faucet water pressure devices. Hooked up to my outside water faucet (which first routes through the inside pressure regulator), it showed 45. I'm told that's "normal." However, when I turn on the kitchen faucet after it's not been used for awhile, the pressure/force of the water coming out seems high, then quickly backs down. Both my toilet valves have started acting odd/filling high in the tank, and my master bath faucet has been dripping on and off.
The question! Despite what the pressure guage shows, would you suspect the household water pressure regulator is indeed going bad and needs replacement?
