c789
Hi. I have a PureGen water softener with a meter valve. The mineral tank is 10" x 54". The softener is set to regenerate after every 2,075 gallons used. Usually it will regenerate once every 14 days. My problem is that day 1 and day 2 after regenerating at 2 a.m., the water pressure is low and the water is not clear. Days 3-14, the water pressure is normal and the water is clear. What is causing the low water pressure and the unclear water for the first 2 days after regenerating? The problem goes away by itself by the third day after regenerating. I have had this water softener for many years without any problems. This problem started last month. If the unit regenerates at 2 am on Sunday morning, then I will have low water pressure and unclear water in my house for Sunday and Monday, but things get back to normal on its own by Tuesday all the way until the unit regenerates again. I use water from the city, not a well. Any help would be appreciated. Thanks.
