Anon5656
Hi, we are out of country and our smart water shut-off system is detecting a high-pressure of >80psi in the pipes. It's showing about >80 psi which is higher than the typical 50 to 60 psi seen in my house.
My house is in Seattle area.
To mitigate the issue, I shutoff the water to inside the house remotely and my friend checked the house and drained all the water in the house as a precaution.
But there is another problem.
The incoming water(from city) to my house forks into 2, one for the house water supply and the other for the fire sprinkler.
My smart water-shut off, that I used to shutoff water at my house, is only for the fork of the pipe, that feeds water to my house, but not to the fork that feeds to fire sprinkler
Therefor the high pressure is still sitting on the water, that feeds to the fork of the pipe to the fire sprinkler.
I've not done any testing for the water pressure to the fire sprinkler in the last 1.5 years.
Any thoughts/suggestions on what I should do next? Any contacts/recommendations would be appreciated. Worried that the fire sprinkler pipes might burst, but the pipes read 175psi.
I don’t know if my 2010’s office has a pressure reducing valve.
See pics, showing normal pressure at my house of 55, but currently reads 85psi.
