Hello,
I was hoping someone could help with an issue I am having with well water pressure. Well is 90 ft deep with 6 inch casing, hit water at 20'. Drilled down to 90'. Set 1/2 hp sub pump at 80'. Have 35 gallon pressure tank installed also. All done by well installer. Was told well was giving out 13gpm. I was told this would be enough cover a 12 zone rainbird irrigation system and a 3 bed 2 bath home. It is only the wife and I though. Most wells drilled around here are 160' ft deep with 1 hp sub pump on them. Of course, irrigation put in and by the time it gets to middle zones it is decreasing in pressure and pulsating. When outside faucet is turned on, there is no pressure for the sprinkler heads. Do not have home finished enough to see inside pressure while sprinklers are going but I know this is not good. Well installer said to just water at night and there MIGHT be enough pressure for a shower. The well installer said that going deeper and putting a bigger horsepower sub pump would not make a difference, I am asking someone to explain to me how this would not help the matter. Also, if someone has other solutions they would be greatly appreciated. I am sure I am leaving some much needed info out and will be glad to provide, ( I am a newbie to all this). Thank you very much for any response.
