Gurrenteed
Here's the background:
My 4 bedroom house was built in 1994. There is a 3/4" copper supply line that comes through the foundation and later splits into pex for the rest of the house.
I recently was looking at installing a sprinkler system and found that the static pressure coming into my house is 130 psi! I initially didn't believe the gauge and thought it must be faulty, so I took the gauge to work (I'm a firefighter) and tested the pressure readings on a fire truck outlet and the pressures matched. The pressure gauge is good.
If I crack open any faucet in the house while the gauge is in place, the residual pressure drops to less than 60 PSI. If I fully open the faucet, the residual pressure drops below 30 PSI.
PRV - the pressure reducing valve is a 3/4 Zurn Wilkins #70. I found the adjustment to be all the way in, which I believe provides the highest pressure. Adjusting this valve did nothing to the static pressure but it significantly reduced volume to almost nothing.
I know I need to either replace or rebuild the PRV. Could this valve also be causing my volume problems? Thanks.
