I'm a novice/customer looking for counsel. I recently had my water service line upgraded from the street main into my residence. The old line was a lead 1 inch. The new line is 1.5 inch copper. I was expecting some increase in water pressure as a result of the work. The water pressure change is not noticeable.
Shortly after entering the house, the 1.5 inch line reaches the meter. The line coming out of the meter is 1 inch. A foot or so later, the line changes back to 1.5 inches, runs 25 feet to just before the water heater, and then converts back down to 1 inch. Is this a proper way to run the lines--changing the size of pipe up and down? Could going back up to 1.5 inch pipe reduce pressure along the line? I should also mention the plumbing throughout the rest of the house is two-years new and to code.
Thank you.
Thank you.
