mistagenki
Have a 3000 sq ft home, wide 1 story. One side of house gets nearly instant hot water (one bath, two sinks, laundry), while other side of house further from tank water heater (2 baths, 3 faucets) only gets about 65% as hot. Just moved in earlier this year, and would love to take a hot shower in the master bath!
I have gone through the steps I find online to detect crossed pipes, but have not had much success. There is no valve to turn off only hot water after water heater to troubleshoot easily. There is a valve on the cold to the whole house after the water heater, that I turned off to see if the cold side on any faucets would run, showing some crossover. While I did not get any flow out of the cold side on any faucets, I did find the water pressure from the hot side now to be much lower, almost a trickle from single-handle tub faucets throughout the house. The pressure increased if I turned on a cold water valve (even though no cold water was present). Not sure what that means.
I am not excited about having to excavate the slab where the pipes are laid, so hoping there is something else I can do. Any advice would be much appreciated!
