Water neutralizer stays in backwash mode
codmanri
Rhode Island
I have a water neutralizer, aquapure cbw1501. The last few times it has auto-started the regeneration cycle it stayed in constant backwash and never completed - water just kept draining for an extended period of time. I had to manual turn the dial to get it to trigger the end of the cycle and stop draining water out.
If i start the cycle manually it never seems to go past the first few pins (shouldnt it only be 2 mins/pin?). The clock still appears to be keeping time.
I am new to these systems and trying to figure out what needs to be replaced or if there is any further troubleshooting i can do. Also wondering how long I should be expecting the backwash/drain cycle to take if working properly? Appreciate any help/advice.
Bannerman
Ontario, Canada
I suspect it maybe time to rebuild your control valve.
With a piston, spacer and seal design, the seal rings can swell, wear or abrade over time, resulting in the piston no longer being able to slide smoothly within the cylinder. If friction increases to an amount greater than the force the drive motor can provide, then the piston can become jammed in the cylinder and cannot advance to the next position.
While the link to the 2 Fleck models which Reach4 provided appear to be very similar to your valve, the inlet and outlet connections appear to be much different on your valve.
ditttohead
Water systems designer, R&D
Ontario California
Correct, that is a proprietary valve made by Fleck. Look at the white tag on the timer door and you will see the manufacturing date. I am guessing 30 years old...
Sounds to me like you got your moneys worth on this one, might be time to upgrade to a newer Fleck unit.
ditttohead
Ontario California
Not likely but not sure. I would not recommend it. From the picture it looks like an old pressed fiberglass tank. These are good for 30 years then they start to weep water. You will usually start to notice some discoloration on the tank, then it will start to get white spots on it which indicates it is now leaking. It would not be worth the risk. The newer tanks are a seamless one piece molded design that is wrapped in fiberglass and epoxy. These are considered more reliable and longer lasting, assuming the tank neck doesn't crack. The old pressed fiberglass tanks rarely had cracked necks but catastrophic tank blowouts were normal.
As to a new one, are you wanting to do it yourself. I know of many companies that sell high end equipment, and many more that sell junk. Stay away from big box stores and the large online dealers who focus heavily on lowest price/marketing garbage. Many of the online companies have switched to all Chinese equipment in order to be $1 cheaper than the next company.
