Hi All,
The main water supply line coming off of the meter pit (rural water) into the basement has started a very slow drip due to what appears to be corrosion on one of the fittings (see pictures).
I've repaired and soldered copper pipe before, so the replacement isn't too intimidating...since this is the main line however, I did want your advice on how to best disassemble to prevent damaging either the poly supply line, or the 3/4" copper supply line that feeds the downstream 1/2" copper and fixtures.
Would it be best to disconnect the 90 degree from the poly first, then spin the clean out fitting off the 3/4" copper? Or should I just hold the 90 stationary with a wrench and spin the clean out fitting up and off of the 90 degree first?
Any suggestions on what new couplers/fittings you would use? I don't see a need for a clean out on the supply line given we are on rural water (clean), but maybe you all see benefit in it?
Any input is appreciated!
