doc5md
The 3/4 bath below is going to be installed in an area that was previous a porch, but has been since removed. in it's place, a footer was dug, conrete poured and a short block wall built. moisture barrier was placed in the resulting crawl space, and then the area was framed out using 2x6's for the exterior walls and 12" i-joists for the floor support.
Access to the crawl space from the basement for the plumbing runs is easy as there are existing holes in the foundation from the porch supports.
The waste plumbing will be easy and I've already posted here about it. I am now more concerned with keeping the pipes from freezing.
So, my question is:
Where would you run the supply lines? The green walls are the new, exterior 2x6 walls, the thick yellow wall behind the toilet, etc is the old brick ext wall, that will be firred out with 2x2's. We are in north central PA.
So, my question is:
