Water line sizing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by HBM, Jun 11, 2019.
  1. HBM
    HBM New Member
    Jun 11, 2019
    Virginia
    I just had a 5 bed/bathroom two story plus basement home built and have a question about my water line size. Originally they installed a 1 inch poly line which was damaged.....after the fact I realized they replaced it with a 3/4 in line (and of course my builder/excavator both assured me it was fine) PSI at the main is around 120. Distance from the main to meter is 35 feet and distance to the house from the meter is 150 feet (house is downhill about 10 feet in elevation). 2 feet after entering the home it converts to a 1 inch regulating valve with 1 inch pex trunks for about 10 feet In the basement ceiling which then goes to 3/4 inch another 30 feet in each direction. I have the prv set at 70 psi in the basement.
    I notice pressure issues mainly if 3 showers are running at the same time or 3 hose bibs are running sprinkers. (This doesnt happen much but my wife has mentioned pressure fluctuations while showering).
    One or two showers at a time are fine which is why I dont think it would be worth digging my yard up at this point.
    Is there anything I can so inside the house to improve this problem? Extend the trunk lines to 1 inch? Extend 1 inch lines all the way to the water heater?
  2. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing- - fire suppression
    New York
    Your have volume issues for sure. Hopefully you have anti scald type shower body's
  4. Terry
    Aug 17, 2004
    [​IMG]
    Your home is about 43 fixture units.
    I normally would have used a 1-1/2" poly or PVC line for that amount of volume needed and the the distance. PEX would be 1-1/2".
    Maybe adding a good sized expansion tank would help at this point.
    Just an example. My parents place was 250 feet from the meter to the house. The irrigation system I installed wouldn't work with the original 3/4" from the street meter. By changing the line to 1.5" PVC, the irrigation system worked fine. The heads that wouldn't pop up were now spraying a good amount of water in each zone. Same meter, different sizing on the line.
    3/4" would be too small for a one bath home and you have five?
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    If you had pressure gauges before and after the PRV, that could be useful in seeing where the pressure drop is occurring.
    A bigger PRV could be called for. A bigger service line could be called for.
  6. HBM
    HBM New Member
    Jun 11, 2019
    Virginia
    I can adjust the prv to get a psi up to 90-100ish. It is a 1 inch zurn 1-600xl
    Where would the expansion tank go? After the prv, before the water softner? Any link to them?
    Thank you guys for the reply
  7. fullysprinklered
    fullysprinklered In the Trades
    Jun 15, 2014
    self-employed plumber-electrician doing residentia
    Georgia
    Use two PRVs, one for each direction at the split.
    Reach4 likes this.
  8. HBM
    HBM New Member
    Jun 11, 2019
    Virginia
    Fullysprinklered,
    Sounds like a good idea to maximize the 120 psi from the main. Do you think doing the split to hot and cold would be better for all the showers?
  9. HBM
    HBM New Member
    Jun 11, 2019
    Virginia
    Also I'm not sure my water softner would handle 120 psi which may pose a problem
  10. Terry
    Aug 17, 2004
    Most codes only allow up to 80 PSI.
  11. Reach4
    Sep 25, 2013
    Maybe have a regulator (PRV) for the softener, another for all other indoor use, and no regulator for the outdoors. If you do any plumbing changes add provisions for pressure gauges to know what is going on. A boiler drain valve is useful for water sampling and for mounting a GHT pressure gauge.
    I am not a pro.
  12. jadziedzic
    jadziedzic Member
    Aug 4, 2006
    New Hampshire
    Was the incoming water line downsized with your permission? (No.) Since the answer is no, perhaps it is time to have a talk with the builder and have them fix their "mistake". If they're reluctant to do so a chat with your local Authority Having Jurisdiction might help, given the replacement is not sized properly.
    This mistake will likely nag you the entire time you spend in your new house.
    OLD TIMER likes this.
  13. OLD TIMER
    OLD TIMER Member
    May 18, 2019
    FLORIDA
    Yea, that's what I would do.
Similar Threads: Water line
Plumbing Forum, Professional & DIY Advice Heat Pump Water Heater Relocation and Condensation Lines Jun 8, 2019
Plumbing Forum, Professional & DIY Advice Main water line Jun 1, 2019
Plumbing Forum, Professional & DIY Advice Black crud (iron?) in water lines May 22, 2019
Plumbing Forum, Professional & DIY Advice Yellow Gas PTFE Tape on Potable Water Line May 3, 2019
Plumbing Forum, Professional & DIY Advice Prevent water line freezing in apartment garage May 2, 2019
