Oconnellshawn88
So this is in wisconsin and it is a duplex setup not currently rented and whole house is still used. So plumbing was done back probably in 70s and imo ran very inefficient and improperly. Am replacing all the waterlines to pex and are currently copper/steel. So ill layout my current plan and open to all input. Its city water which comes into softner except the line that goes to spicket and refrigerator. From the softner i plan to run to run to a checkvalve, then tee to a expansion tank, then use a bullnose T to a 50 and a 40 gallon electric heaters offset so that equal amount of pipe and distance is used measuring to the bottom of the water heaters. Then again at equal distance do the same merging then running to the fixtures in a main 3/4” line. Was planning on running 3/4” to both the wash machines but am having difficulty finding oxbox or similar and wash machine shutoff valves that accept 3/4” pex a expansion connection so probably end up just teeing off with 1/2” like rest of the home. So will then be 3/4x1/2x3/4 to the kitchen sinks, the bath vanities, lastly the shower will have 3/4x1/2x1/2 with return line to recirculate hot water which will tie in with a check valve and tee after the check valve from the softener and before the tee to the expansion tank. Some things i read say not to run parallel system with different size tanks tho. Bust then most sites say not to run in series anymore. What is the best/most cost and enegry efficient way. Fyi not currently worried about billing as duplex and if needed will just add a few cheap thread on water meters down the road that run to the fixtures to determine water usage to accurately divy up the bill unless someone knows a better way as well. Is a recirculating pump required or needed?Thoughts/advice/comments/concerns? Thanks
