Banjo Bud
Active Member
i put a riser pipe in at the high point in my run. As you can see in the picture it comes up to ground level and is capped. I plan to prime it there if it needs it. At the least, I will uncap it to allow air to escape while I prime it at the pump. My question now is about the possibility of the water in the riser pipe freezing. I’m near Charlotte, NC, so it’s not bad here but still, we do get freezing temps. So, if I prime it at the cap, and look into the riser pipe while priming, and don’t allow the water to come up the riser pipe, will the riser pipe stay that way? Void of water? If so, I have no worries. If however it will eventually have water in it, it may freeze and break. So any suggestions to address that possibility are welcome. I thought of making the pipe shorter and surrounding it with a 4” or 6” PVC and insulating that. But not sure how I would screw and unscrew the cap while holding the cap base so as not to break the pipe off. Thanks guys.
