Water level dropping in well housing
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Lathelms, Jul 8, 2018.
  1. Lathelms
    Lathelms New Member
    Jul 8, 2018
    NC
    I lost prime on my well while filling a child's swimming pool. I've primed this well pump many many times successfully. This time though, as I pour in the water into the top of the pump, the water level just keep dropping so that I can pour water in at a trickle almost continuously and the well housing still won't fill. I have zero pressure. Any ideas on how to prime this pump when it won't hold water?
  2. LLigetfa
    Feb 6, 2011
    Retired
    NW Ontario, Canada
    Not sure what you mean by well housing. I assume you mean the pump housing. Is there a packer in the well?
    When you ran out of water, did it get murky? Perhaps the pump sucked in sediment which is now preventing the foot valve from sealing.
  4. Lathelms
    Lathelms New Member
    Jul 8, 2018
    NC
    Yes, you're right, it's the pump housing. I opened up the hexagon shaped screw on top of the pump and poured in about a gallon of water until it filled up and ran over. Instantly the water I had poured in began receding. Usually this opening stays full of water and then I would put on the screw and hit the power and its primed. This time when I pour in water it just seeps down inside the pump and I have to fill the entire thing. And yes, the water had become murky and cloudy just before it ran out.
  5. Boycedrilling
    Boycedrilling In the Trades
    Sep 30, 2013
    Royal City, WA
    Your check valve at the bottom of your drop pipe isn’t sealing.
  6. Lathelms
    Lathelms New Member
    Jul 8, 2018
    NC
    Thank you for the info! Sounds like it's time to call for an appointment with a professional. I get lots of sediment build up in the filter screen on my washer too so that seems very likely the cause of the problem with the well. Thanks!
Similar Threads: Water level
Pumps and Tanks Well Forum & Blog. Water is life. Well static water level May 12, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Level sensing pump req for a water softener... Dec 13, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Best way to monitor levels and store extra water for a vacation rental? Aug 29, 2017
Pumps and Tanks Well Forum & Blog. Water is life. water level rose with jaswell seal Aug 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. 1/2hp water jet pump struggles w low water levels Oct 3, 2016
