Water in kitchen floor, where is it coming from?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Angela Hutton, Apr 21, 2020.
  1. Angela Hutton
    Angela Hutton New Member
    Apr 21, 2020
    Alabama
    I thought it was coming from my old washing machine. I got rid of it and bought a "new" used machine. The tech delivered it and set it up and checked to make sure it was not leaking. It was not. Today there was water on the kitchen floor again. No clue where it came from. The only water that was ran today was in the kitchen sink. It does leak a little under there, but not to that extent and no way for it to get from there to several feet across the kitchen. I'm stumped.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Crawlspace or slab?
    Failures in the drain lines from kitchen sinks is not uncommon. Clear out the things under the sink. Any sign of water under there?
    MASTERPLUMB777 likes this.
  4. WorthFlorida
    WorthFlorida The wife is still training me.
    Oct 28, 2009
    Retired
    Orlando, Florida
    Sometimes the faucet will leak only when the water is in use. It happened to my son, once in a while a lot of water. We cleared out the cabinet, dried it out and sure enough in the morning there was water. We replaced the faucet. You might want to place paper towels on the bottom of the cabinet to catch water. Do you have a dishwasher?
  5. plumber69
    plumber69 In the Trades
    Jun 20, 2014
    Prince Rupert, British Columbia
    Could be anything, keep filling your sink up and dump water like 5 times, see if water shows up, could be a broken water line. I had a guy that thought he had a foundation leak. but ended up being the copper drain line in the wall
  6. Angela Hutton
    Apr 21, 2020
    Alabama
    No dishwasher. It does leak a little under the sink. The pipe under the sink leaks. I have a bowl under it to catch the water. Still don't see how it would get from there to a few feet away in the floor.
  7. Reach4
    Sep 25, 2013
    Through the wall, to the slab, under the bottom of the cabinet and across the slab to the puddle. The santee may have failed, or the pipe below the santee may have failed. That is one possibility.
  8. Angela Hutton
    Apr 21, 2020
    Alabama
    what is a santee?
  9. Reach4
    Sep 25, 2013
    That is short for sanitary tee. The vent pipe goes up from there. The trap arm of the trap goes out the side to your p-trap.
    [​IMG]
    This is one in plastic, but yours might be steel or cast iron. Those can fail. The steel pipe into the bottom of a metal santee can fail.
  10. Chucky_ott
    Chucky_ott Member
    Apr 13, 2018
    Ontario
    Put a marble on the floor close to any water source to see if it rolls to the location where the water accumulates. Could be a low spot in your floor.
    Check the fridge too. I have a brand new one that started leaking on the floor. They generate condensation but generally that should evaporate before leaking anywhere. Ice maker too.
    Also, check the ceiling. What's up there?
  11. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    Water flows down hill. Your floor is not as level as you might think it is.
  12. Angela Hutton
    Apr 21, 2020
    Alabama
    Two plumbers out in as many days. He couldn't get it to leak, so he didn't fix it. It's intermittent, apparently. I still want it fixed. He looked at the leak under the sink, didn't want to fool with it either. Can't believe nobody wants to do anything.
  13. Angela Hutton
    Apr 21, 2020
    Alabama
    A second specialty drain plumber came out, ran the washer, it didn't leak and the water had dried up. So he did nothing! I'm so frustrated! Do they think I'm lying about it? Ugh!
  14. plumber69
    Jun 20, 2014
    is it coming from under toekick
  15. Angela Hutton
    Apr 21, 2020
    Alabama
    what is that? It came from two different places today. It was in front of the washing machine today, and then behind the wall again. I heard it gurgle that time.
  16. Reach4
    Sep 25, 2013
    How many units are above you?
  17. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    "Behind the wall" - Is the wall wet? could be a supply pipe running in the wall.
    "Gurgle" - Where is this sound coming from? Are you in a single story?
  18. Angela Hutton
    Apr 21, 2020
    Alabama
    yes, a very old single story mobile home
  19. Reach4
    Sep 25, 2013
    If the leak under the sink is reproducible, I would think they could fix that. Post a picture that shows the bottom of the sink, where the drain goes into the wall. Try to show the pipe from the side.
    Have you had rain lately?
  20. plumber69
    Jun 20, 2014
    If it hasn't been raining then don't use sink or dishwasher for 2 days. If water doesn't show up then its a drainage issue. take pic of under sink
  21. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    Keep a dry towel at the sink as if it is a rug, when it gets wet you might be able to tell from where to leak is coming from by how wet one particular area is. Gurgling usually means a backed up drain or sewer line. Is this mobile home connected to a septic tank or a city sewer connection?
Similar Threads: Water kitchen
Plumbing Forum, Professional & DIY Advice No hot water kitchen faucet Sep 4, 2020
Plumbing Forum, Professional & DIY Advice Water leaking under kitchen sink. What to do? May 1, 2020
Plumbing Forum, Professional & DIY Advice Water leaking in back of kitchen cabinet and through exteior wall, Please help! Apr 27, 2020
Plumbing Forum, Professional & DIY Advice Hot water coming out of Kitchen Cold Tap Apr 24, 2020
Plumbing Forum, Professional & DIY Advice No hot water in kitchen only. New faucet/supply line, hot water in all other faucets Apr 16, 2020
