I have a geothermal heating system for the house which also heats my water. The system is set up so the heat exchanger in the geo furnace preheats well water and sends it to a 50 gal water heater used as a storage tank (not hooked up to electric), then over to a water heater with power to step up the temp before sending hot water out to the house.
The problem I'm having is that the storage water heater, the one without power has failed and started leaking water 2 times in the last 8 years. I'm now on my third water heater/storage tank.
Some other facts:
Previous (original) water heater lasted 28 years and was still working when they installed the new 50 gallon electric heaters with the geothermal system.
I have no problems with stained fixtures and the 30+ year old faucets have not shown abnormal corrosion.
I change anodes in water heaters every 5 years and there's always plenty left on the anode. I have not had the storage tank side heater long enough to change an anode since they've all failed in less than 4 years time.
I have not had the well water tested for ph but intend to do so.
Plumbing is polybutylene piping.
Heaters have all been AO Smith brand.
My question is why are these tanks failing so fast?
One though I had was that it could be because the storage water heater tank is not powered so it's not grounded? That's the only thing I can think of that's different between the two. Or is it just bad luck?
Some other facts:
