brisdale
I have a house with 3.5 bathrooms and currently two A.O. Smith ProLine GCR-50 400 gas water heaters (in parrallel) that are around 11 years old. Given the hard water conditions here, I figure I'm on borrowed time and want to replace them before they fail. They're located in the garage where they're easy to access. If possible, I'd like to recover some space for storage, and I do plan on adding a water softener eventually.
Over the 11 years I've lived here, we've never had hot water issues. We regularly run 2 to 3 showers simultaneously, sometimes with the dishwasher running too (family of four). That said, even with this usage, the two 50-gallon tanks feel slightly oversized, but I could be wrong.
I initially considered going tankless, but after calculating the cost, it doesn't make financial sense. The payback period would be 10+ years given the price difference and installation costs (and honestly, that's not really a DIY job for me).
That leaves me with two main options:
Option A: Replace the two 50-gallon units with two 40-gallon tanks. This won't recover much space, but it has lower upfront costs and a simpler DIY installation since it's essentially a drop-in replacement.
Option B: Replace both 50-gallon units with a single 75-gallon fast recovery tank. This would give me nearly the same first-hour gallon rating. I could keep it atmospheric, allowing me to reuse the current vent configuration (two 3-inch pipes merging into one 4-inch pipe). Alternatively, I could go with a power vent model and repipe the vent out the wall, which might improve efficiency and recovery. I'm open to opinions on whether that's worth it.
My questions:
My questions:
- Am I crazy for considering downsizing to a single heater? Should I just keep the two and call it a day?
- If sticking with the two, Is it better to not downsize to 40 gallons and stick with 50-gallon units instead?
