I just want to be sure that its ok/code to use a pan under a water heater and have it plumbed to a drain and just let the pressure relief tube hang open over the pan. I was told that it was not allowed to run the pressure tube 'directly' to the drain because it can get clogged and it not be known.
Its just not 'feasible' right now to run the pressure tube directly to the outside from where this old water heater sits. I was curious where this would be found in the plumbing code where the pressure tube cannot be run directly to the drain. Thanks.
