lightsareout
I hope I have created this in the right section, it is water heater related....
I need to connect our water heater drain pan either to another drain pipe or to the exterior of the house. As a DIYer just getting it outside the house is the easiest for me.
I'll try and explain where the WH is located. We are in the south so the WH is in the garage. The garage is at grade level and there is about 16" from the garage floor to the top of the first floor - the WH is raised up under the interior stairs so at the same level as the first floor.
I think I have 3 options, maybe there is a better approved way
1) plumb down into the crawl space with 1" PVC, attach to the bottom of the joists but then angle up to drill a hole through the rim joist and siding and exist. This will be lower than the height of the pan.
2) plumb down into the crawl space with 1" PVC and around the joists back into the garage 6-10" above the garage floor, running slightly or parallel to the garage flooring and exit the house through the wall/siding next to the garage door (to grassy area not cement). This may sound like more work but less time in the nasty crawl space!
3) just plumb with 1"pvc to the step up to where the water heater is and run along the garage wall and exit the garage wall (no time in the crawl space).
