Water heater on the fritz... Tub damage?
MTy
TN
Just finished renovating my master bathroom. Filled the 60 gallon acrylic soaker for the first time last night. After about half fill water turned yellow/brownish murky color. Also left a similar color film at the water line. Thankfully I was able to clean the film off.
I'm thinking it's iron or sediment from the heater. It's 50 gallon electric AO Smith, about 8 years old. Question is can it stain my tub if I continue to use it until I replace the heater?
I would be replacing it this coming weekend if dumb and dumber at Homers hadn't dropped my new heat pump water heater on it's side while loading it on to a box truck... :mad:It had a ramp, how hard can it be?
The heater is out of stock so don't know when I can order a new one. Maybe flushing the old heater could buy me more time?
Put a hose on your water heater and get it flushed out. That should help a lot in the meantime.
As far as dropping the new tank, they are kind of heavy. It's always nice when there is a second set of hands for that.
MTy
TN
Thanks. I thought that might help.
There were two Homers associates, and they weren't small guys either, loading it and they had a pallet jack and the truck a ramp, should have been simple. I knew you shouldn't get advise at Homers but you'd think they could load a truck.
