Today I tried to drain my heater for the first time since moving in and I encounter two things. First, the cold water valve doesn't shut. You can turn it either way but it wouldn't shut. What do you think the problem is and how can I fix it? Second, if you look at the second image, I see some rust along the pipes connecting to the expansion tank. Will this be a potential issue? Thank you
