GrandPooba
I just moved into a 3-story townhouse. The ground floor contains the garage, utility room, and entrance way. Living areas are on floor 2 and 3.
The utility room is approx 7x15, and contains the water heater, gas furnace, and W/D. There is no drain pan below the water heater, nor is there a floor drain.
Is there a water resistant barrier that I can erect around the water heater to minimize minor leaks? Recommendations on pump and/or wet vac? What other precautions should I be taking?
