gkdiamond
I have a few questions?
I have a gas water heater that is installed in my garage. After it was three or four years old I started noticing that a lot less water was coming from the hot water side of my faucets even if they were turned all the way on. I turned off the gas and opened up the drain but everything looked okay. I shut the water valve off then disconnect the flex tube on the hot water side. The tube is copper on the wall side and is sweated to the copper pipe. On the side where it connects to the heater it has a brass nut. The opening just above the brass nut where the copper tube starts was almost completely sealed with what looked and felt like black metal. I couldn't even stick a screwdriver through it. Because I didn't want to attempt unsoldering and replacing the tubing (the right thing to do!) I ended drilling through the deposit and reeming it out and yes I knew there was a possibility that it might start again. The cold water side was just fine.
My water heater recently went out after over 15 years. The tubing on the hot water side is again almost plugged up with just a slit across the middle. I am going to use a flex tube that has nuts on both ends so that it can be replaced easily. My question is why is this happening? The nipple coming out of the hot side of the water heater is the standard looking shiny silver metal (not sure what kind). I thought the brass nut was suppose to prevent this from happening. Unless the copper tubing is somehow making contact with the nipple?
Does changing the Anode rod approximately every 5 years really make the heater last any longer? My heater sits on an 18" pedestal so there is no clearance to remove the rod. The heater would have to be tilted forward. My heaters T&P valve is soldered to copper pipe and plumbed through the wall were it exits and terminates with an 90 degree elbow outside several inches above the ground. On the new heater, I would either have to make the pipe disconnectable (not sure if code allows it) or just bring a length of pipe down the side of the heater so that it can be tilted with the heater. Any suggestions on how to best make the pipe disconnectable (if allowed) or would it just be better to bring it down the side? Is it even worth changing the rod?
I'm also wondering why the builders and their plumbers do not put a drain pan under the heater when they install it and just charge a little more to cover the cost? They certainly know it's going to leak.
