Property owner has an existing shallow, low-yield well feeding a 3,000 gallon atmospheric storage tank for landscape irrigation. He wanted more volume so he had a second shallow well drilled approx 150' lateral distance from the first well. The discharge from the first well flows through 1" PVC pipe and simply dumps into the top of the storage tank. The 1" PVC discharge pipe from the second well was spliced into the discharge pipe from the first well using a tee fitting: the discharge from the first well flows straight through the tee, while the discharge from the second well flows into the tee from the side port.
The first pump continues to operate as before with no problems. But when the second well is run with its output throttle valve opened to any reasonable amount of flow (>3 gpm), there is tremendous, continuous water hammer in the discharge pipe; this is while the pump is running, not when it stops. The water hammer occurs whether or not the first pump is operating. I suspect that the hammer is caused by the way the water enters the tee from the side and then has to turn 90 degrees abruptly to the tank fill pipe, while also creating standing pressure waves in the pipe leading back to the first well. Thoughts?
I'm planning to replace this tee connection with a wye so the water from the second well enters into the common tank fill pipe at a 45 degree angle. Thoughts?
