A Carter
Hi, I just purchased my first home and was going to switch out our whole house sediment water filter, when I noticed that the filter housing was installed backwards ("in" at the outlet and vice versa). It looks as though it is connected to the copper pipe with compression fittings, so I think I can handle taking the filter housing off and putting it back on with the correct orientation. However, I wanted to check to make sure it is as straightforwards as I am thinking it is.
I am also concerned about some discoloration of the pipe at the inlet. No signs of water leaking in that spot, but should I be concerned? If so, any ways to fix it that I might be able to handle (fairly handy, but not extremely handy)?
