Hello, I'm installing a new under sink water filter and faucet. The filter is a simple single stage GE filter with one inlet for supply and one outlet to faucet. The filtered water faucet is an old Eco Pure model that I thought can be used with a simple system like mine or a Reverse Osmosis systems. The bottom of the faucet has 2 barbs (3/8 and 1/4), and instructions say to only use the 1/4 barb for reverse osmosis system. After hooking up line from outlet of filter to the 3/8" barb on the faucet, the water keeps shooting out the vent valve on the faucet vent valve above the sink line.
What did I do wrong?
I don't have a clamp on the barb yet, but I assume that's not the cause. Clamp was out of stock at store. Will try again elsewhere.
Also, for compression fittings with ferrules and nuts, I have always used teflon tape on the threads. Is that wrong? Should I stop doing that?
Thanks in advance you for your help.
