JOSEPH SMOOT
Good Morning! I'm new here, just joined and searched for this question and was unable to find the answer.
Can you turn a Wye on its Y, for lack of a better term? For those that like to read, I explained a lot below the photos. For those who don't look at the photo and tell me if it is a- okay or a no go, Please.
Can I turn a 3" Wye diagonally, so it essentially acts as a 45 bend with a 45 that I could reduce a 3" to a 1.5" and tie my kitchen into it? The only reason I ask is if I do that VS just whats there now (a standard wye) it'll buy some space in order to make the turn into the existing stack. I've attached some photos to show what I want to do. I don't see why not, but that's why I'm asking for a little help.
I bought a home that was in need of some serious repair. I've gotten pretty far, submitted my permits and such but have a quick question or two.
I'm doing my waste plumbing, I have a septic (which is getting replaced) so I will have the ability to move and replace my soil stack / clean out to the tank. As of now, i'm going to connect it so I can test and sparing use my system (septic field is functioning, but not well).
All in the same area, I'm connecting a
- 2" for my washer > sink > pump w/ check valve
- 2" for my tub overflow / drain
- 1.5" for my kitchen sink
My plan is to use a 90" with a 2" side ell for my shower since my tub drain/overflow is real close and a 3>2" wye sits too far forward. AND then have my kitchen sink connect into the 3" after the 90 (vertical now).
I'm in NJ and new to home owner ship, let alone plumbing. I work in a mechanical trade with electrical and hydraulics so I get the basics of flow and connections, and I've done as much research as I can but haven't found a yeah this is fine or no this won't pass. Thanks!
For those curious, I did 3" clean out > 3x 3x1.5 wye (vanity / d/w) > 3x3x3" wye (toilet) > 3x3x3" wye on a 45, with a 45 to the 3" vent > 3x3x2 wye (washer/sink/pump) > PROPOSED 3x3x2 90 w/side ell (Currently just a 90) > PROPOSED 3x3x3 Wye w/reducer (currently a 3x3x1.5 wye for the kitchen sink)
Vanity/ DW and Kitchen sink have their own vents that will tie into the 3" in the attic. shower/overflow isn't installed yet in the photos but its a tight corner over there since it's right below.
Thanks a ton!
Thanks a ton!
