parvinr
- Messages
- 13
- Reaction score
- 0
- Points
- 0
ok my washing machine dumps water to drain upstream from the kitchen sink and and then on the the hub where it empties into the main soil pipe i have shaked and snaked until im blue in the face. on a med. hot load in the washing machine with no clothes when it empties air is pushed up the sink drain now if i pull the j flex tube out of the washer drain just a little air comes from this location which leading me to believe the vent are stopped up or sized wrong it is 2'' cast pipe with 2'' vent at the sink and 1 !/2"" vent at the washer i have run snake down the vents and also stuck water hose in them also seems to be flow through both if i try to plug the sink off then the water backs up into laundry room behind washer what would you recommend
