Hey Guys - searched through a dozen threads to see if this was already covered, and couldn't find a dedicated answer.
I've got an old wetbar in the basement (with 2" standpipe), that I'm using for the utility tub drain (1 1/2 into 2"). The house is only 4 years old, so should be up the latest Ohio codes.
There is no vent above the floor. I believe that this is because it is only about 6' from the main vent stack (3" pipe, 4" at the floor). Further up the run, is the drain for the kitchen upstairs. I imagine this gets a vent somewhere upstairs closer to the p-trap. Perhaps it may also run as a wet vent right now for the utility tub?
Currently, the washing machine is draining into the utility tub with no issue, but I want to plumb it permanently into the supply box. I am stymied on what to do with the vent.
1a) should that come off the main vent stack (kind of don't want to cut into 3" pipe and then step down to 2").
1b) should it be a wet vent over from the upstairs sink?
2) since I'm venting the washing machine arm of the drain, I might as well vent the sink arm as well. Perhaps like this?
3) Screw it, drain into the utility tub.
Thanks for all the help and support!
