woppermann
Hello all,
I just purchased a Haier HLP23E Compact Washer. I would like to permanently install it in a closet which currently does not have water or drain hookups. I believe I can get water to it without any problem, but have questions about draining. The only way I can install a drain pipe is by coming down from the attic. The pipe would have to come down approx 4-5 feet from the attic and then go straight across the attic approx 10-15ft. I don't know if the washer's pump will be able to pump the water up and out to the outside of the house.
Is there a way to solve this? Perhaps an additional pump, similar to a condensation pump for an AC unit?
Thanks in advance.
Will
Thanks in advance.
Will
