Washing machine drain, stand pipe, P-trap considerations
isotope
Texas
index.php
This is a really clean build of this washing machine box, stand pipe, and P-trap. If only I was so lucky to have this much space. Anyway, I have a couple questions about the P-trap and spacing...
Check out the attached picture. Isn’t the P-trap supposed to be attached so that the vertical part of the P-trap is connected to the stand pipe? And the smoother transition of the P-trap follows onward from there? It is not like that in the picture.
Also, the washer is in the corner of a room and I have some space and obstruction issues that prevent me from putting the vent pipe in the same stud bay as the P-trap. Would it be ok to put the vent pipe into the next stud bay? In order to do so, the short piece of pipe connecting the end of the P-trap to the sanitary tee would have to include a 90 degree elbow because the next adjacent stud bay is on wall that is at the corner of the room. Does that make sense?
What is the vertical part of the P-trap? In the photo, the vertical PVC pipe connected to the box is the standpipe. On the left you have a sanitary tee. The pipe above the santee is a vent pipe, and the pipe below is a drain pipe.
isotope
Texas
Sorry. I wasn’t clear in my questions. The first question, I was just wondering about the orientation of the p-trap, and which side should connect to the drain. The U shaped portion of the p-trap has a “sweep”side. It’s not a big deal though. I think the sweep side can connect to either the vertical drain or to the other side closer to the horizontal drain pipe.
The second question I had was... would it be acceptable to use a 90 deg elbow between the trap and sanitary tee? I just can’t fit everything in one stud bay, and need to route the piping around a corner so I can put the vent pipe into the next stud bay.
Got it. It works fine both ways, but the opposite of the photo is preferred. https://terrylove.com/forums/index.php?threads/proper-p-trap-orientation-flow-direction.74831/
I think that is OK to have a long sweep in the horizontal. Maybe medium even. I am not sure. . I am not a plumber.
isotope
Texas
Ugh! I don’t have room for a long sweep elbow to get around the corner. Does anyone know if a standard 90 deg elbow is ok?
Vertical to horizontal needs to be long. There are different opinions on using medium for horizontal to horizontal I think.
isotope
Texas
What about a horizontal to horizontal connection. Do I have to use a long sweep 90?
