Washer P- trap needed
C M
Louisiana
Hi all. I have a question about the need for a p trap. A plumber put in my washer dryer lines and connected drain. See first pic, there is nothing else to the left of the washer dryer line, it's all drain outside the house from there. At first he didn't have a p trap in there at all but a friend mentioned something about it so he added one under the WD box.
I'm wondering, if p trap is supposed to stop sewer gasses, what is stopping those gasses from passing over to my dishwasher and sink that is on nearby wall connected to same drain? Do I need another p trap? Or should p trap be to the left of the WD to stop gases for the whole drain line instead of just the WD part.
The washer needs a vent for the p-trap. The vent goes above the trap arm, not below the p-trap.
In the Seattle area the washer box is normally installed with hammer arrestors.
  • Like
Reactions: C M
CountryBumkin
Active Member
Orlando, FL
The vent for the Washer P-trap should be where the cleanout cap is shown in the second picture.
The sink and dishwasher will have its P-trap installed under the sink (in the cabinet) when the sink is installed so it would not be in the picture (not in the wall).
  • Like
Reactions: C M
C M
Louisiana
Thanks for the info / advice. I was also told there is no fall in the drain line which would eventually become problematic... sigh...
CountryBumkin
Active Member
Orlando, FL
It looks like new construction (or a remodel) so you should have a plumbing "permit". If so, the inspector should catch the mistakes we are talking about. But either way, you should stop working with the plumber you have now and get another plumber (or at least another professional to look at the work). Once the walls are closed up it's going be hard and expensive to make corrections.
I do NOT see any "cleanout". That is an AAV which is installed improperly. The "vent" next to the washer trap is completely unnecessary and useless, but it does make a nice decoration. You need a plumber, NOT a "handyman" to install your plumbing.
