Washer machine in basement
Ulbin3
New Jersey
My sister in law bought a small cottage in Massachusetts she is gutting the whole house and its going to be a complete renovation for all the plumbing.
In the basement the sanitary pipe leaving the building is around 22"from the floor above the code of 6"- 18" of a washer machine stand pipe trap.The original builders just rough in the trap around 26" not sure how it passed inspection.
What is the solution for this situation? The obvious answer for me would be to install a pump into a utility sink or move the washer dryer to an upper floor.
Terry H
Alabama
I’m a fan of those little basins with a sump pump in them. They can save a lot of money in certain situations and save a bunch of work. I think it would work great here since you don’t have to grind sewage or anything and it’s just moving water basically.
If it was my house Id leave it at 26 put an 18 inch stand pipe and decide from there whether to use a seperate box for the waste and put the water lower. Id try to make it look good . but no Im not going to put a pump in . not my house Ill do it on someone elses and get paid for it. I want to do good job but installing a pump just adds another mechanical thing to fail
Ulbin3
New Jersey
Could you clarify? I don't understand what you are saying.
Ulbin3
New Jersey
WorthFlorida
Solutions
Orlando, Florida
There are millions of homes in the NE built during the 50's and 60's where the sewer connection was usually somewhere half way up the basement wall. The same as the home I grew up in and the washing machine drain was alway high above the main trunk. You'll probably find that the inspector will let it pass. If not it is very easy to add a utility sink with a basin pump. They are very reliable and a utility sink is extremely convenient to have in the basement.
Ulbin 3 sounds like we have a failure to comunicate ! are you pumping because the trap is a few inches high? or because there is no waste line whatsoever in basement? If waste comes into the house 22 inches off floor above how would your toilets and bathtub drain? So you most certainly are not clear . please clarify as nothing looks obvious to me here
wallhanger
Kansas
Speaking as an older person with arthritis, if the house is being completely gutted, (and I assume cottage means small) is a stacking washer and dryer setup on the ground floor worth consideration?
Ulbin3
New Jersey
