JR_Well
I was going to simply replace all components, but have read about the packer adapter. I am fairly sure this is just a shallow well with a single pipe. As you can see the pump uses an adapter to connect to the offset 2 inch pipe. The well casing is outside the house and is 4 a inch pipe. Am I correct in assuming this is just an adapter, single line with foot and check valve? I can tear into this and not worry about a feed pipe and leathers?
