BIGBREW
Good afternoon Gentlemen. I’m looking to boost my water pressure a little bit. My current set up is as follows.
140ft well runs in 1” to the pressure tank. Switch is set to 40/60. 3/4 comes out of the pressure tank goes through a mixer for a small shot of peroxide, through my air injection tank, softener, uv light them to the main house supply.
My water treatment system is in the basement on the opposite side of the master bedroom where my walk in shower is with two heads.
House is 60’ long. 3/4” runs from my water treatment system, all the way to the far end of the house where the master is, 1/2” water lines T off the 3/4” for faucets, toilets etc where necessary.
My pressure in the bathroom isn’t horrible, I can run both shower heads currently. I would just like a little more pressure, maybe #10 ish lbs on the far end.
I was thinking about installing a boost pump between the softener and UV Light after my treatment system so it’s not running as well during regen cycles in the tanks.
Like I said, gaining 10-20lbs on the far end would be really nice.
I was looking around and saw something like this…
What would you recommend?
